Hello good folk of the LTT forums,
I've had it for a while now but I cannot help but wonder. How bad is it to have your PC directly on carpet?
I've seen a few posts where people say that you get issues with static electricity, increased dust and suffocating your PSU if the fan faces downward. With this in mind I would like to ask you how much of an issue is it really?
Also whether it is serious or not what would be a good way to get my PC off the carpet that does not involve a piece of wood? I know the corsair 760T has those little stands which creates space for anyway bottom mounted fans or PSU's for which the fan faces downwards, is there such a thing you can buy separately for any case?
-Archangel
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/195246-pc-case-on-carpet/
Depends, is your PSU at the bottom of the case, drawing air from underneath? If so, best not to have it on a carpet. Even more so, if it's a thick carpet. I personally have mine propped up on 2 big thick books, one of them is a copy of the Third Reich, the other is a big bible lol.
tl;dr best to keep it off the carpet. Prop it up with some old books, or something which can take the weight, and is durable enough.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/195246-pc-case-on-carpet/#findComment-2647934
-Archangel
Peice of carbord, PC on that
Peice of anything hard, Pc on that.
Any of these
http://www.amazon.com/Econo-Mobile-Stand-Light-IVR54001/dp/B001E69W3U/ref=pd_sim_sbs_e_8?ie=UTF8&refRID=1RV9HK62EATZ01ARNFFD
http://www.amazon.com/Syba-SY-ACC65010-Stand-Plastic-Adjustable/dp/B002LVUIS0/ref=pd_sim_sbs_e_7?ie=UTF8&refRID=1RV9HK62EATZ01ARNFFD
http://www.amazon.com/Allsop-Metal-Art-Caddy-27761/dp/B00009MGBD/ref=pd_sim_sbs_e_6?ie=UTF8&refRID=1RV9HK62EATZ01ARNFFD
http://www.amazon.com/Syba-Computer-Castor-Wheels-SY-ACC65063/dp/B0096KK76W/ref=pd_sim_sbs_e_5?ie=UTF8&refRID=1RV9HK62EATZ01ARNFFD
http://www.amazon.com/3M-Adjustable-CPU-Stand-CS100MB/dp/B000KI8HKC/ref=pd_sim_sbs_e_4?ie=UTF8&refRID=1RV9HK62EATZ01ARNFFD
http://www.amazon.com/Syba-SY-ACC65029-Castors-Plastic-Adjustable/dp/B003BYRO7O/ref=pd_sim_sbs_e_3?ie=UTF8&refRID=1RV9HK62EATZ01ARNFFD
http://www.amazon.com/IO-Crest-BlackComputer-Caster-SY-ACC65057/dp/B006V9AUMC/ref=pd_sim_sbs_e_2?ie=UTF8&refRID=1RV9HK62EATZ01ARNFFD
http://www.amazon.com/Kantek-CS200B-Mobile-Stand-CPU/dp/B001AJS3BS/ref=sr_1_1?ie=UTF8&qid=1407689976&sr=8-1&keywords=cpu+tray
https://linustechtips.com/topic/195246-pc-case-on-carpet/#findComment-2647938
Even on floors, it still collects a lot of dust. So I would put some elevation on it. I put mine on a table to keep it off the floor. I hear that dust hovers near ground level.
https://linustechtips.com/topic/195246-pc-case-on-carpet/#findComment-2647959
Say I made a wooden frame for my pc so that my pc sits about half a meter above the floor would that dust hovering around ground level still be an issue?
https://linustechtips.com/topic/195246-pc-case-on-carpet/#findComment-2647967
Nope. Before, when I put my pc on the floor, there was dust everywhere. When I elevated the PC, almost no dust comes through.
https://linustechtips.com/topic/195246-pc-case-on-carpet/#findComment-2647973
