Good In-Ears With Solid Cable
Sennheiser IE4. I don't know about extremely sturdy, but the cable is more rugged than on most in-ears.
http://en-de.sennheiser.com/earphones-headphone-stereo-passive-noise-reduction-ie-4
I have a CX870, which is discontinued now, but i had absolutely no problems with the cables so far.
VSonic VSD3 and VSD3S have a removable cable, meaning you can replace it if it breaks.
Sennheiser's cables suck. How long have you had the CX870?
Two years. Before that I had an MX65VC, did not have a problem with that either. What really sucked though, was the MX75. The cables looked like a salad after a year, so I get where the whole 'Sennheiser cables suck' thing is coming from. They are a lot better today though.
I had an IE60 and the cable broke within 6 months.  -_-
WTF. At that price, it definitely should not happen. What did you do with it?
The plastic/rubber isolation came off of the wire near the right earpiece during normal use. Technically, it still worked, but I was uncomfortable wearing it after the wires were exposed.
The RMA process was painless, but I still feel the cable should've been better for the price. I sold the replacement because I didn't want the same issue to happen again, and have been perfectly happy with sub-$100 IEMs since.
Totally understandable. It's a shame though, i was thinking about buying an IE60 as a replacement.
