In-Ear Help
Go to solution Solved by AfroLedgend,
I just bought Audio Technica'a ATH CKX9iS Sonic Fuel IEMs and they have an excellent sound stage, really good sounding bass, and clear treble. they are within your budget also.
http://www.amazon.com/Technica-ATH-CKX9iS-Headphones-In-line-Control/dp/B00EO3DYQ6/ref=sr_sp-atf_title_1_1?ie=UTF8&qid=1407624422&sr=8-1&keywords=audio+technica+ckx9is
http://en.goldenears.net/40595
So I need audiophile help.
Price range is sub $100 US
I am currently looking for in-ear headphones that are not super base heavy, preferably just flat. Good build quality.
| 3570k @ 4.5 | swiftech h220 ordered after patent issues | EVGA 660ti SC 3gb | 8gb gskill ripjaws | Asus p8z77-v lx | Corsair Ax 750 | Asus Xonar DS | Corsair C70 white | CM quickfire rapid mx browns | G500 |
https://linustechtips.com/topic/194899-in-ear-help/
Dreadnaught: Intel Core i7 970 3.2GHz, Silverstone TD-02, ASUS Rampage III Extreme, Kingston Fury White 24GB 1866MHz, Crucial BX100 250GB + Seagate 2TB SSHD, AMD Radeon Sapphire R9 390 Nitro, NZXT S340 White, Bitfenix Fury 650W, BenQ XL2730Z.
https://linustechtips.com/topic/194899-in-ear-help/#findComment-2643007
Update I forgot to say memory foam if possible
EDIT: Can i just buy foam tips for the audio technica
https://linustechtips.com/topic/194899-in-ear-help/#findComment-2643020
The Sonic Fuels come with a set of Comply Foam tips as well as the standard S, M, L tips.
https://linustechtips.com/topic/194899-in-ear-help/#findComment-2643149
Just got those. Thanks alot for the recommendation.
https://linustechtips.com/topic/194899-in-ear-help/#findComment-2643706
Sure thing, I hope you enjoy them as much as I am. Be sure to run them in for a while just playing music through them.
https://linustechtips.com/topic/194899-in-ear-help/#findComment-2643818
