Computer build help?
Solved by MTROB,
PCPartPicker part list: http://pcpartpicker.com/p/HfRTZL
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($338.99 @ NCIX US)
Motherboard: Asus Z97M-PLUS Micro ATX LGA1150 Motherboard ($126.98 @ SuperBiiz)
Memory: Corsair Vengeance 32GB (4 x 8GB) DDR3-1600 Memory ($324.99 @ NCIX US)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($51.99 @ NCIX US)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply ($67.99 @ Micro Center)
Total: $910.94
The Corsair 350D fits mATX mother boards.
If you don't need the 32GB of RAM for After Effects, you can get less. The CPU comes with a cooler, but if you are going to overclock you would need a better one.
The only reason to get a workstation board, is if you have something like a network card, or other pci card, that you need to be sure the board will work with. If you don't have a network card or other pci card, a non workstation board will work fine.
