Logitech g500 vs g402
Realistically you should compare the generations, not the models like you are now.
The G402 ($60 USD) and G502 ($80 USD) are model refreshes, and have newer sensor tech and I would try to pick these guys up over their older counterparts: the G400s and G500.
The G402 is the simpler of the two refresh models and is everything you should need for gaming without being excessive, therefore the lower price. Also it's optical. You can see why that's a big deal HERE: http://linustechtips.com/main/topic/190207-optical-vs-laser/#entry2561818
The G502 has weight tuning and scroll wheel modes. I really like having scroll modes for browsing, but these two features don't impact my gaming much at all. It's up to you if that's worth an extra $20, but I can't possibly recommend old models like the G400s and G500s. They look terrible, and the extra buttons will be lackluster and not nearly as responsive as the new ones.
