I only get around 150 or so FPS on a standard survival world, which is far lower than I expected I'd be getting with my specs. This isn't a problem by itself, however if I install shaders the frame rate dips below 60 very often, and stays below 60 at all times if I decide to record with shaders on. In fact, with shaders I get the same FPS as I would in Skyrim + the 160 mods I use (mostly graphics mods).
I've asked a couple of people about their frame rates and some of them say mine seems right, although others are somehow able to get very very high numbers. For example I changed my settings to match that of a person with a 780, we stood in the same spot and he was getting around 700 FPS while I was only getting 200 ish, also neither of us were using any performance enhancing mods.
I'm really not sure if my frame rates are right. I've done a bit of research and I get the feeling that perhaps my graphics card drivers aren't treating Minecraft as a game, or perhaps it's using the iGPU? I've disabled the iGPU in BIOS though and I've added Minecraft to Catalyst Control Center so I'm not too sure if this is the case. In case it's relevant I've also allocated 3GB of RAM to Minecraft and I'm using Java 8 64 bit, though I've tried Java 7 which gets me the same frame rates.
i5-4670k @4.2GHz Sapphire Tri-X R9 290 @1135MHz 1600MHz G.Skill RipjawsX 8GB Samsung 840 EVO 120GB Samsung 850 EVO 250GB
Corsair K70 Logitech G502 Proteus Core Logitech G230 Blue Snowball SteelSeries QcK+
YouTube // Steam // Twitter // Facebook // Google+
https://linustechtips.com/topic/194616-minecraft-lower-fps-than-expected/
Minecraft is horribly optimized.
update drivers for everything. check what size your texture pack is. run optifine. check CPU and GPU temps. make a baked potato. Make sure you're running the latest and greatest version of MC and Java. Try without mods, if any are installed. Overclock.
That's all i got...
Linus once unboxed a Toblerone
I get about 200 on my GTX 760 and 4670k. something is likely wrong.
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
Could it be that AMD cards don't handle Minecraft well? All the multiple hundred FPS people I know use Nvidia.
I have similar specs and I consistently get more than 250 fps, but I'm using optifine.... try that
XEON E3 1231v3 | GA-Z97MX GAMING 5 | XFX R9 290 | 16GB RAM | CRUCIAL MX100 256GB | WD BLUE 1TB | EVGA SUPERNOVA 850W | CORSAIR 350D
I have an r9 290, and my fps is often above 300...
Now its time for people to say that minecraft is "badly optimised" even though they havent seen the code for minecraft, and probably dont know Java or anything about programming.
Programmers over at Spigot even say it's badly optimized
Linux "nerd".  If I helped you please like my post and maybe add me as a friend :)  ^_^!
Well, I've never seen any performance enhancer in any other game do as good of a job as Optifine.
Try using Raptr or CCC to optimize your settings
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
