Hi, i want to buy the Cooler Master Hyper 212 EVO but i dont know how to install it and if it will fit in my case Cooler master cm 690 ii and my motherboard Gigabyte ga-990xa-ud3. I also have no idea how to install it, will i be able to install it without taking out my motherboard?
https://linustechtips.com/topic/194256-will-it-fit/
It will for, look up installation videos
https://linustechtips.com/topic/194256-will-it-fit/#findComment-2633198
It will fit, there's enough room for it to clear the opposite side panel. And to install it, use the instruction manual and installation videos on the youtubes, they'll help you to install it.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/194256-will-it-fit/#findComment-2633217
https://linustechtips.com/topic/194256-will-it-fit/#findComment-2633225
Yes
https://linustechtips.com/topic/194256-will-it-fit/#findComment-2633233
there is a cutout on the motherboard tray to install backplates, so yes, you can. Just remove both side panels and away you go.
PCs
https://linustechtips.com/topic/194256-will-it-fit/#findComment-2633258
For future reference, be sure to check out specs online :)
CM 690 II product page - CPU Cooler compatible height up to 177mm
Hyper 212 EVO product page - Only 159mm tall
If you ever need help installing something, be sure to look into the instructions that come with the products, contact support teams where relevant (Here's Cooler Master USA support), and look for YouTube tutorials as well!
Cooler Master USA representing! Looking for help? Head to the CM Fanzone to get in touch with the Customer Support team!
https://linustechtips.com/topic/194256-will-it-fit/#findComment-2636005
