NZXT Switch 810 compatibility question
Solved by cooperred,
In the OCN build log, it looks like the board is covering a few of the cable management grommets. It should fit, but it won't be listed as compatible
Issac Zachary ·
Posted in Troubleshooting1 -
4
PopsicleHustler ·
Posted in Audio4 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
4
thrasher_565 ·
Posted in Hot Deals0 -
6
play_circle_filled
Latest From ShortCircuit:
