Hey guys,
You are probably familiar with that case from Corsair, so i just wanna ask about the hard drive installation.
In my case it is a difficult situation. I wanna watercool a CPU and a GPU, and for that i need 2 dual 240 or 280 radiators. In order to have a 280mm rad on the front, I've got to remove the drive cage, leaving me with 2, 2.5-inch SSD mounts on the back of the motherboard tray. I will easily put 1 ssd and 1 2.5" hard drive in them, but:
1. There will almost be NO airflow passing through them
2. HDD will be mounted vertically, which i dont usually see them around that way...
In that case, will the hdd performance or lifespan be affected by this?
Is there another case where i can mount that hdd to get somekind of airflow?
Intel Core i9-9900K | Asrock Phantom Gaming miniITX Z390 | 32GB GSkill Trident Z DDR4@3600MHz C17 | EVGA RTX 3090 FTW3 Watercooled | Samsung 970 EVO 1TB M.2 SSD | Crucial MX500 2TB SSD | Seasonic Focus Plus Gold 1000W | anidees AI Crystal Cube White V2 | Corsair M95 | Corsair K50 | Beyerdynamic DT770 Pros 250Ohm
https://linustechtips.com/topic/193904-hdd-mounting-problem-450d/
For SSDs there is almost no need for airflow as they don't have anything to generate heat. As for HDDs, you can easily fit 2 or even 3 3.5'' HDDs to 5.25 mounts. Just get converters or converter box for them.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
