So I have a combo of Rosewill redbone u3 case and Msi B85 G43 motherboard.
I was looking to purchase more fans(for bottom and/or replace the fans that came with the case), preferrably in red but I can paint them no problem(just want to avoid taking fans apart).
Silence is not biggest concern; I am trying to run two r9 280x(have one installed, one sitting on the side because I know it's probably not going to get enough cooling if I put it in; unless I install a bottom fan in front of psu).
What fans(both 120mm and 140mm are needed) are of good performance?
4-pin slot for fans means speed is adjustable from motherboard, right?
Also, should I go with a regular old Coolermaster 212 Evo for cpu-cooling for Pentium g3258?  No better option for the price came out. right?
Thanks.
Anyone who has a sister hates the fact that his sister isn't Kasugano Sora.
Anyone who does not have a sister hates the fact that Kasugano Sora isn't his sister.
I'm not insulting anyone; I'm just being condescending. There is a difference, you see...
https://linustechtips.com/topic/193737-fan-cooling-questions/
If you're on a budget, get the 212 to cool the pentium. If you can fork out the extra cash, a dark rock 3 would be a good choice as well.
For fans, the nf-f12s by noctua, noiseblocker e-loops or black silent pros are good, along with bitfenix spectre pros and silverstone air penetrators.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/193737-fan-cooling-questions/#findComment-2626202
Yeah, F-12s and A-14s if you're not concerned about silence. (though p-12s are a better compromise of performance/quietness)
4-pin means the fan is PWM enabled. This generally means the motherboard controls the speed to adapt to temperature, and user customisation of these PWM speeds is a feature on a few select motherboards only.
https://linustechtips.com/topic/193737-fan-cooling-questions/#findComment-2626771
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/193737-fan-cooling-questions/#findComment-2626890
i am geting NZXT Source 530 CA-SO530-M1 and if dose not come with a front fan i was wondering what type of front fan i shud get for max air flow what is quiet
http://www.newegg.com/Product/Product.aspx?Item=11-146-114&cm_mmc=SNC-YouTube-_-NETV-_-UhOvuc3vRpw-_-11-146-114
https://linustechtips.com/topic/193737-fan-cooling-questions/#findComment-2629621
