cooling my fx 6300
skitz9417
hi people from overclock.net i have a fx 6300 overclocked to 4.7ghz at 1.46ghz cooled by a nh-d14 and i have been wanting to change my case as well it just a crappy areocool gaming case and i was think of changing my nh-d14 to a coolermaster nepton 280l cooler
http://www.netplus.com.au/product/FNCONEPTON280L/CoolerMaster_Nepton_280L_CPU_Water_Cooler_All_Socket_RL-N28L-20PK-R1
and maybe this case
http://www.netplus.com.au/product/CABISHINOBI-03/BitFenix_Shinobi_Black_Gaming_Case_SHINOBI-BK_Chassis_No_PS
or a cheaper on i live in australia as well any thoughs
amd fx 6300  @4.4ghz @1.4/ga-970a-ud3/HD78702gb /antec 620w psu
There is no point in changing your cooler that you have right now, it will perform a little worse if not the same as a 2 fan RAD. For the case Define R4 or Arc Midi R2
Geezus 4.7 GHz!  I have my son's at 4.2 GHz but have not touched the voltages at all.
Too many ****ing games!  Back log 4 life! :S
or i was thinking of going push pull
or i can have it at 4.5ghz on 1.41v
There is no point in spending that on something that will be marginally better. Spend the money on a SSD or something or just not spend it
ok thank u
actually whats a the safe temp for the fx 6300
and maybe this case
You sir, won the silicon lottery.  4.7Ghz at 1.46 volts is nuts!
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
Well TJMax is 90 I think, so I'd keep it under 80.
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
highest i hit with occt is 70 that it
