good day to all..
i'm in a middle of troubleshooting some old school pc here
the motherboard is not booting up..
this is an ECS G41T -R3 with a dual core intel procie..
these are the things i already did
*power on the PC, psu fan, cpu cooler fan starts to run.. then shuts down
(suspected that it was a PSU problem due to age, dust accumulation and being a generic one)
*bought a new PSU (CM VS2 500W) replaced the old one tried to boot it up.. again same action.. only fans ran up then shuts off again..
(suspected that the casing was grounding the components)
*removed everything out of the case, tried to boot up.. no more spin.. no sign of turning on.. tried to touch the motherboard then got a shock
so it was clearly there is power in the motherboard.. but why it wont boot up..
i'm suspecting that the motherboard is dead.. but i'm not 100% sure
so guys, can you help me out? thanks in advance :D
PS: if there are still things i haven`t done yet please share it and post it here
https://linustechtips.com/topic/193545-motherboard-problem/
if you can take it out from the case
then run the CPU and Ram only
see if it posts
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/193545-motherboard-problem/#findComment-2623338
