Games in windowed mode feels laggy/clunky on primary monitor. (Using 2 monitors)
The "issue" you are talking about is how Windows prioritizes things when they are focused. Basically, if a window is not focused Windows won't use as much resources to keep that window performing at max potential cause why would you want something that you aren't looking at to be running at 100% when the resources can be used for something else? It's not an issue, it's just how Windows works
I actually talked to a friend of a streamer I mod for who works at Windows, and it turns out, you're half right. It's that, in combination with force V-Sync on the aero theme. On a 60Hz monitor, you shouldn't notice as much of an impact as a 120Hz, or 144Hz, but it will be there. The limited resources due to Windows processing window focus, and then the V-Sync forced by Aero combine on a 144Hz to give you just terrible lag/ low FPS. Disabling Aero would certainly help, but you'll still have some lag.
