Games in windowed mode feels laggy/clunky on primary monitor. (Using 2 monitors)
herecomestheking
Go to solution Solved by SlayerOfHellWyrm,
The "issue" you are talking about is how Windows prioritizes things when they are focused. Basically, if a window is not focused Windows won't use as much resources to keep that window performing at max potential cause why would you want something that you aren't looking at to be running at 100% when the resources can be used for something else? It's not an issue, it's just how Windows works
I actually talked to a friend of a streamer I mod for who works at Windows, and it turns out, you're half right. It's that, in combination with force V-Sync on the aero theme. On a 60Hz monitor, you shouldn't notice as much of an impact as a 120Hz, or 144Hz, but it will be there. The limited resources due to Windows processing window focus, and then the V-Sync forced by Aero combine on a 144Hz to give you just terrible lag/ low FPS. Disabling Aero would certainly help, but you'll still have some lag.
Yeah, so you're used to a much lower OEM cost, and having that factored into the PC price. If you want it cheaper, just buy an OEM copy. The only real difference is you only get a single use with OEM, and it's tied to the Motherboard it's activated on.
I agree but there's only one problem. It's hard to find OEM copies here
  • CPU:  AMD Ryzen 7 7800X3D
  • Motherboard:  MSI PRO B650M-A WiFi
  • RAM:  G.Skill Trident Z5 RGB 32GB (2 x 16GB) DDR5 Memory @ 6000MHz
  • Graphics:  Colorful iGame GeForce RTX 3070 Ti Ultra W OC 8G-V
  • StorageKingston KC3000 2TB M.2 PCIe NVMe Gen4 SSD; Seagate Barracuda 2TB Hard Disk Drive @ 7200rpm
  • PSU:  Cooler Master V1000 1000W 80+ Gold
  • Case: Corsair 4000D Airflow
  • Keyboard: Cooler Master CK550 RGB Mechanical Gaming Keyboard w/Gateron Red switches
  • Mouse: Glorious Model O- Wireless @ 1600dpi, 1000Hz
  • DAC: JDS Labs OL DAC
  • AMP: JDS Labs O2 AMP
  • Headphones: Hifiman HE-400I w/ZMF Ori Lambskin pads
  • Soundbar: Creative Sound BlasterX Katana
  • Monitor 1: BenQ EL2870U @ 3840 x 2160, 60Hz
  • Monitor 2ASUS Predator XB252Q @ 1920 x 1080, 240Hz
  • Monitor 3AOC G2460 PQU @ 1080 x 1920, 144Hz
