Pc 350 driver problem?
tl:dr Got my pc 350se' two hours ago, sometimes audio stops playing from the right speaker completely. Should i return them or is there something on my end causing the issue (i don't have a amp but when i asked if i could power these you guys said i should be able to power them, my mobo is a asus P8Z77-V LK. The only audio program i have running is Razer surround.
https://linustechtips.com/topic/193032-pc-350-driver-problem/
Try wiggling the connector to see if that does anything. It might be a loose connector on the mobo. If you have any other devices, try the headset on those to see if you have the same problem. If the problem happens on other devices, then that would point to a defect on the headset.
https://linustechtips.com/topic/193032-pc-350-driver-problem/#findComment-2616851
1. plug that thing to your smartphone and see if same thing happens 2. the mobo is fine 3. if that right speaker is causing problem still then its unfortunately broken :( should have had gotten the pc350 se edt. ^_^
If one does not fail at times, then one has not challenged himself.
https://linustechtips.com/topic/193032-pc-350-driver-problem/#findComment-2616866
Will do
https://linustechtips.com/topic/193032-pc-350-driver-problem/#findComment-2616886
They are 350se forgot to mention that
:D okay that is really unfortunate, I personally have those since june last year and they are in crazy good shape still, have no probs running these on my z77x-d3h mobo, must be smthin with the driver then :/
https://linustechtips.com/topic/193032-pc-350-driver-problem/#findComment-2616893
