I am looking for the quietest all black static fans out there...preferably in 140 mm. I would like to keep it cheap...I am planning on build my own desk and they are for radiators in the side of the desk.
If you've previously won the build off please pm me so we can get something worked out.
https://linustechtips.com/topic/192804-static-fans/
Too expensive they are like 20 a pop.
You can get them off ebay for $10-12 a piece, I just ordered a ton, they're all in perfect condition.
https://linustechtips.com/topic/192804-static-fans/#findComment-2613374
Eh I actively try to avoid eBay cause of past experiences with it.
https://linustechtips.com/topic/192804-static-fans/#findComment-2613380
That's what ebay buyer protection is for :)
https://linustechtips.com/topic/192804-static-fans/#findComment-2613385
https://linustechtips.com/topic/192804-static-fans/#findComment-2613399
Rosewill Hyperborea 140mm, Black, sleeved cable, quiet, good static pressure, PWM, inexpensive at around $12 per fan and can be found for less.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/192804-static-fans/#findComment-2613411
I have suggested those but people tell me Rosewill is no good even tho I have never had a problem with them.
https://linustechtips.com/topic/192804-static-fans/#findComment-2613417
Rosewill hyperborea's are extremely good, they'd be fine.
https://linustechtips.com/topic/192804-static-fans/#findComment-2613441
https://linustechtips.com/topic/192804-static-fans/#findComment-2613452
They bash Rosewill because they are a more budget oriented brand, Hyperborea's are great and people who bash them are stupid and can keep spending twice as much for their fans for all I care, I know what's good.
https://linustechtips.com/topic/192804-static-fans/#findComment-2613487
Get the rosewell hyperborea's they are the best you'll get for such little money, a word of advice for the future, don't bother looking at decibel ratings they don't say anything about how quiet the fan actually is.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/192804-static-fans/#findComment-2615607
