Hello!
I have problems with my internet connection. I should get around 10 Mbps from my ISP but i only get like 6.7 Mbps. I made a test, there is a speed of 9.5 Mbps to from ISP to my router, but from there on through UTP to my computer
it is just 6.7 Mbps as i said in the begining. I replaced like 3 routers, but they all have same resault. What should i do? By the way im using cat 6 cables and my current router is Technicolor TG788vn v2. I contacted my ISP and they have no idea what to do.
http://medialibrary.technicolor.com/c/333/p/7e9bc902de54da866f1054108c2881cd/Datasheet-MediaAccess-TG788vn-v2-External-Use-all-audiences-Publications-xDSL-Advanced-Gateways-Datasheet.html
Can someone help me?
https://linustechtips.com/topic/192574-internet-connection-problem/
I've re-read a couple times and I'm a little confused. You're wired in right? Like Ethernet.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
