HELP!!! I just turned on my desktop and it I got a BSOD. After restoring it windows booted incredably slow along with everthing else. I checked the task manager and it said it was uding 100% of 255 MB. I NEED HELP ASAP!
EDIT:  I unchecked the "Maximum Memory" Box on the right Shown Here and now everything shoud be fine. Thanks for your help guys
FX-6300 @ 4.1 MHz; Cooler Master Hyper 212 Evo; XFX Radeon 7870 Core Edition; Arock 970 Extreme 3; Corsair CX600; Corsair Vengeance Blue 8GB(2x4GB) DDR3 @1600MHz; Seagate Barracuda 1TB; Zalman Z9 Case
Asus U43F-BBA7; i5-460M @ 2.53GHz; Crucial 8GB(2x4GB) @1333MHz; Intel 520 120GB SSD
https://linustechtips.com/topic/19204-help/
What was the error code.
It was most likely your memory or the harddrive.
As suggested by "mdgtman91" reinstalling your RAM and do some test (Memtest) to check the memory.
I could'nt see the error code because it flashed to fast and then rebooted. I found an article that MAY have the fix but I just checking it. It seems to be a value in msconfig got changed so im ATTEMPTING to try and open it while my computer is chugging along. If that ends up not working Ill report back with the memtest results
https://linustechtips.com/topic/19204-help/#findComment-226090
Can't be a HHD failure otherwise it won't boot.
Memory seems to be the problem. If you have multiple stick try swapping them out one by one.
Check your connections if they are all properly seated. :)
Run programs like memtest, kombustor and prime 95 for at least 12 hours or until you BSOD again. :))
CPU: i5 -2400 Cooler: Noctua NH-L12 Mobo: Fatal1ty Z68 Pro Gen3 Memory: Corsair Vengeance 8gb 1600mhz SSD: Samsung 840 120gb HDD: WD 3TB Green, Seagate Barracuda 1TB GPU: Asus GTX 760 Direct CU II (future SLI) Sound card: Xonar Phoebus PSU: Corsair RM series 750 watts Case: Aerocool Mechatron Fans: Bit Fenix Spectre Pros
Monitor:Samsung SyncMaster SA950, Philips Blade 234CLSpeakers: Logitech z506 Headset: Razer Tiamat 7.1 KB: Blackwidow Ultimate Stealth edition Mouse: Ouroburos Mouse pad: Golaithus Extended Speed edition Gamepad: Orbweaver Controllers: Wireless Xbox 360 Controller, Razer Hydra
System: Razer Edge Mouse: Razer Orochi Mouse pad: Razer Vespula Controlers: Razer Sabertooth (2 pcs.) Headset: Razer Blackshark Speakers: Razer Ferox What can I say, I'm a huge fan of Razer.  :D
https://linustechtips.com/topic/19204-help/#findComment-226156
Try to flash your bios too!
https://linustechtips.com/topic/19204-help/#findComment-226157
