Can someone link me a good waterblock that will fit on a XFX 290X DD?
CPU  i7 6700K @ 4.7GHz | Cooler: Swiftech H220 | RAM: 16GB Corsair Vengeance | GPU: EVGA GTX 1080 SC | Motherboard: Z170X Gaming 7 | PSU: EVGA G2 650W
Storage: 128GB Kingston SSD/1TB WD Black Storage | CASE: NZXT Switch 810 | MONITOR: Acer GN246HL | KEYBOARD: CM Quickfire TK (MX Blue) | MOUSE: Sensei Rival
https://linustechtips.com/topic/191350-290x-waterblock-help/
https://linustechtips.com/topic/191350-290x-waterblock-help/#findComment-2583103
So if it says visual compatibility, does that mean its guaranteed to fit?
Yup, according to the compatibility checker the XFX 290X DD uses a reference PCB. That waterblock works with the reference PCB.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/191350-290x-waterblock-help/#findComment-2583117
Thanks, and what does Acetal and nickel mean? I'm new to GPU liquid cooling.
https://linustechtips.com/topic/191350-290x-waterblock-help/#findComment-2583139
It means the waterblock top cover is made from POM acetal (black) while the waterblock itself is copper with nickel plating that better protects the copper against water corrosion.
https://linustechtips.com/topic/191350-290x-waterblock-help/#findComment-2583158
Great! Thanks. Is it safe to run Brass, copper, and nickel in the same loop?
https://linustechtips.com/topic/191350-290x-waterblock-help/#findComment-2583209
Yeah. Pretty much unavoidable nowadays too. As most rads have brass and copper. Aluminum is the one material you should avoid.
https://linustechtips.com/topic/191350-290x-waterblock-help/#findComment-2583232
One more question, what does original CSQ mean on EK's website?
https://linustechtips.com/topic/191350-290x-waterblock-help/#findComment-2583425
It's just a marketing term. Probably one of the cheesiest things EK has done. It stands for Circle SQuare design.
http://www.ekwb.com/shop/EK-IMAGES/EK%20Catalogue%20-%20CSQ%20Design.pdf
https://linustechtips.com/topic/191350-290x-waterblock-help/#findComment-2583460
Will getting just the copper block make a difference compared to the nickel?
https://linustechtips.com/topic/191350-290x-waterblock-help/#findComment-2583550
The nickel plating will keep your waterblocks looking better longer, but you can clean your waterblocks so it's up to you.
https://linustechtips.com/topic/191350-290x-waterblock-help/#findComment-2583614
