I currently have a H100i in Pull configuration. I am about to put it into a push pull config. I dont have enough fan headers on my motherboard to have all those and my other case fans. So I need a fan controller for that. Any suggestions?
Depending on your motherboard & I'm guessing you might have an asus Z87/Z97 board you can run off 3/4pin fan splitters from the motherboard to your fans & in the bios optimize them for low rpm.
What you require are low noise adapters & fan splitter(s)
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/191124-fan-controller/#findComment-2579711
