Definitely not, if you'd just open the case you would see there's no room for a graphics card.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
https://linustechtips.com/topic/191096-will-it-fit/#findComment-2579254
a - no
b - the PSU won't be powerful enough anyway
Lies the 750 ti get it's power directly from the pci-e slot for the reference cooler. The psu is fine.
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/191096-will-it-fit/#findComment-2579288
Hi my name is Rasmus and i just want to know if a GTX 750 TI acn fit in a XC600 Acer Aspire?? i relly need to know becuase its my birthday soon and i need to know what card can fitt in my computer
GTX 750 TI
My Computer
as long as the XC600 has 1-2 free pci-e expansion slots physical it's fine however depending on which 750 ti you purchase might not work. From what I know the original reference 750 ti doesn't require pci-e power from the power supply but some of the other manufacturers like asus, msi, gigabyte & evga.
https://linustechtips.com/topic/191096-will-it-fit/#findComment-2579293
How are you know if it's going to fit?
Because I read the specs he copy+pasted into his thread which is great plus on the website.
I/O Expansions Number of Total Expansion Slots 2 Number of PCI Express x1 Slots 1 Number of PCI Express x16 Slots 1
The 750 ti stock is only a single slot card & other non-reference are dual slot expansion.
https://linustechtips.com/topic/191096-will-it-fit/#findComment-2579375
Sir, I have experince, I got the same computer, 750ti will not fit, but to all who say PSU is not enough, that is a lie. My GPU has a 400W req but it still runs, a 750 ti has a 300W Req, the only problem is it is not lowprofile
It needs to be Low Profile
Computer Specifications:
AMD Ryzen 5 3600  Gigabyte B550M Aorus Elite | ADATA XPG SPECTRIX D50 32 GB 3600 MHz | Asus RTX 3060 KO Edition CoolerMaster Silencio S400 Klevv Cras C700 M.2 SSD 256GB
1TB Crucial MX500 | 1 TB SanDisk SSD Corsair RM650W
Camera Equipment:
Camera Bodies:
Olympus Pen-F Panasonic GH3 (Retired)
Lenses:
Sigma 30mm F1.4 | Sigma 16mm F1.4 | Sigma 19mm F2.8 | Laowa 17mm F1.8 | Olympus 45mm F1.8 | Panasonic 14mm F2.5
https://linustechtips.com/topic/191096-will-it-fit/#findComment-2579548
