Problems with start up or anything else
Go to solution Solved by mvitkun,
everything that godlikegohan said.
also are you sure you put the cpu in the right way,all the way?
when you say it won't start up what do you mean?
do the case fans spin up?
does it not just not post to the monitor?
does the gpu fan spin up?
Hey guys,
So my friend bought new pc and asked me to assemble it. I assembled the components but computer wont start. Power supply works tested with multimeter, led on mother boards lights up and triple checked the cables. I don't know what's wrong with it.
The components:
MSI Z77A-GD65
Intel® Core™ i5 3570K
Noctua NH-U9 "Special Edition SE2"
G.Skill PC3-14900 "RipJawsX" KIT 8gb 1866 MHz DDR 3
EVGA GeForce GTX 660 "SuperClocked" 2 gb gddr 5
tosiba 1tb
Thermaltake Commander ms 1
Gigabyte Superb 720W
Any help i can get i would appreciate.
Sory for bad English not my native language.
https://linustechtips.com/topic/19106-problems-with-start-up-or-anything-else/
check the motherboard manual to make sure you have the ram in the rite slots for first boot.
Rig: Intel i7 920 D0 @3.5 | gtx970 | 12 gig Balistix 1333 @ 8-8-8-24 | 2x1TB Spinpoint F3 Raid 0 | 1TB Spinpoint F3 |samsung 840 evo|  Thermaltake 850w Tp |
Xfi extreme gamer | Antec 902
Peripherals: Samsung syncmaster 2494hs @1920/1080 - 60Hz | Q-pad MK85 | g502 | Razor Destructor | Logitech G930 | Logitech 3D pro xtreme | 360 pad | Nitro Wheel
any error code on mother board.
double check .and make sure all cables plugged in..
like the power for video card.
and case wires
if you can not get it to post
pull mother board out of system. and do a bench start up.to test.
Any signs of activity besides the LED? Do the fans start up? Any speaker error codes? Try with no video card at first, using the MB´s video.
CPU: AMD FX 6100 Stock - MB: Asus M5A97 EVO - RAM: AMD Memory Entertainment Edition 2x4 GB 1600 MHz - PSU: Topower 650W NANO - SSD: Samsung 840 120GB - HDD: Seagate Barracuda 500 GB 7200 RPM - GPU: Sapphire HD 7770 Vapor - X OC - CASE: Aerocool Strike - X Advance (Red/Black) - OS: Windows 7 Ultimate x64
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
