Don't worry I'm not a complete PC noob and I know how to install it I just don't know how to set it up. I just bought an extra 16gb of ram to help render video's and after I installed the new memory I was told to change something in the BOIS. also when I go to my PC hardware it show's that 32gb is installed yet only 16gb is usable (what I had before). My main problem is that I don't know how or where in the BOIS to set it up under. Thanks for helping me out if you do  :)
https://linustechtips.com/topic/190979-i-need-help-installing-memory-yes-really/
Youtube it
Read the OP and not just the title maybe?
To OP: What Matt said above is correct.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
If you are a pc noob I have to ask why you bought 32gb of ram in the first place? If you have someone "helping" with your pc decisions and your upgrade decisions you shouldn't be listening to that person. If you just bought it for reasons unknown to yourself well...i guess stuff happens..
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
