Hanging PC for start up
Go to solution Solved by Shd0w2,
Unplug the power cord and hold down power button for 10-20 seconds, then try turning it on.
I've had my pc for nearly a month and everything was good, but since Tuesday I've been having a problem. When i start the pc sometimes, the asus rog splash screen comes up and it just stays on there, u cant press delete, F2 or esc. I can only restart it with the button on my case or hard shut down it. If i have restarted it or hard shut down it, it boots up but a little bit slower than usual.
I have the Asus Z97 Ranger motherboard, with a 4690k, a gtx 770 and windows 8.1 pro
If anyone knows how to fix this, it would be greatly appreciated, thanks.
        My PC Specs:          CPU: i5 4690k(stock speed of 3.50GHz)          GPU: MSI GTX 770 4GB          Storage: WD Blue 1TB HDD and 120GB Samsung 840 EVO SSD             Ram: 8GB Corsair Vengeance Pro 1600MHz           Motherboard: Z97 Asus Maximus VII Ranger          PSU: Corsair RM650 650W          CPU Cooler: Coolermaster Hyper 212 EVO                    Case: Fractal Design R4 Black Pearl with window         OS: Windows 10 Pro
https://linustechtips.com/topic/190818-hanging-pc-for-start-up/
if i do that, will it permanently fix the problem, or will i need to keep doing it?
https://linustechtips.com/topic/190818-hanging-pc-for-start-up/#findComment-2575053
Should fix it permanently
i just tried it and it worked, thanks for your help
https://linustechtips.com/topic/190818-hanging-pc-for-start-up/#findComment-2575124
