i wouldn't recommend overclocking with that mobo because the vrm heatsinks are not that good. You would spend more money on a asus m5a99fx pro if you want to overclock.
so if i had a better heatsink such as a dark rock 2, could i do some overclocking on it? or is it just the board that wouldnt hold up
No the motherboard is not very good to overclock even you had a hyper 212 evo. I'm talking about the mobo vrm heatsinks not cpu heatsink. Still recommond asus m5a97 r2.0 or asus m5a99fx pro.
edit; the mobo wouldn't hold up as well and be stable.
ok thanks
