SO ive constructed this configuration on MWave.com and need some feedback/suggestions/any problems etc.
Also any recomendations for different parts or similar ones for better prices would be highly appreciated.
My budget is $2000 and my location is South Australia and no i am not building it myself so dont suggest that please.
Thank you  :)
Case: Fractal Design Define R4 Black Mid-Tower Case
CPU: Intel Core i5 4690K Quad Core LGA 1150 3.5GHz Unlocked CPU Processor
GPU: Gigabyte GeForce GTX 780 3GB Overclock Video Card
Mother Board: ASRock Z97 Extreme6 Intel LGA 1150 ATX Motherboard
RAM: G.SKILL RipjawsX 8GB (2x 4GB) DDR3 1600MHz Desktop Memory F3-12800CL9D-8GBXL
HD: Seagate ST2000DM001 2TB Barracuda Desktop HDD 3.5” 7200RPM SATA3 Hard Drive
SSD: Samsung 840 EVO 120GB 2.5" SATA III SSD MZ-7TE120BW
Power Supply: Corsair RM-650 650W 80 PLUS Gold Power Supply
CPU Cooler: Corsair Hydro Series H90 Liquid CPU Cooler
Fans: Corsair SP120 Quiet Edition PWM 120mm Cooling Fan - Twin Pack
https://linustechtips.com/topic/190108-new-gaming-pc-build-need-help/
Looks like a really good build. Maybe replace the PSU by something a bit better ~750-800W if you want to use SLI later.
Laptop: Intel Core i5-4200H, 8GB RAM, 750GB HDD, GeForce 840M
Desktop: Intel Core i3-6100, 8GB RAM, 750GB HDD, GeForce GTX 750 Ti
The only thing I'd change out is the power supply to EVGA's G2 series. I do have another suggestion but I don't know if it's even available in Australia yet. That other suggestion being a Kraken x41. It's a thicker 140mm radiator, meaning better temps, with nicer software and a cooler (at least in my opinion) CPU block. Also the Gigabyte cards are a little loud but it shouldn't be too loud especially in that Define R4 case.
You gotta do you girl. I always say you gotta do you. And if he's doing him, then who's doing you? Because right now, it seems like no one's doing you.
- Stefani Stilton (she / her) 🏳️‍🌈🏳️‍⚧️
