It's my first build but I'll just get to the point
CPU: i5 3570k
RAM: Corsair Vengeance 8Gb 1600MHz
CPU Cooler: Cooler Master 120m Seidon Water Cooled
Storage: SEAGATE Barracuda 7200RPM 3TB
Mobo: ASRock Z77 Extreme 4
GPU: Gigabyte AMD Radeon HD 7970 GHz edition
PSU: OCZ Fatal1ty 750w
Case: NZXT Phantom Full Tower
Peripherals
Mouse: Razer Taipan
Keyboard: Some unnamed Microsoft Keyboard :P
Mousepad: Piece of Paper
Monitor: Acer V273HL 27inch Full HD LED Backlight Monitor with Speaker
Speaker: Bose Wave
Headset: Razer Orca
Is this a good build? Are there compatibility problems? Please let me know!!!!!! Thank You
https://linustechtips.com/topic/1901-first-build-decent/
That is a fantastic first build. Like LimeDK, the best upgrade that you can get would be to get a SSD. Other than that, you're golden.
My Rig:
  • CPU: 1090T@4.1ghz
  • GPU: Gigabyte 7870
  • MOBO: Crosshair Formula V
  • RAM: 8GB 1333mhz
  • PSU: 650w corsair HX
  • SSD: 120GB Kingston HyperX
  • Sound card: Asus Xonar DX
https://linustechtips.com/topic/1901-first-build-decent/#findComment-26059
That is a fantastic first build. Like LimeDK' date=' the best upgrade that you can get would be to get a SSD. Other than that, you're golden.[/quote']
Alrighty when I find the extra money ill get a SSD haha thanks for your input too :D
https://linustechtips.com/topic/1901-first-build-decent/#findComment-26064
That is a fantastic first build. Like LimeDK' date=' the best upgrade that you can get would be to get a SSD. Other than that, you're golden.[/quote'] Alrighty when I find the extra money ill get a SSD haha thanks for your input too :D
Yeah, the difference between a good SSD and any HDD is like night and day. Makes it hard working on other computers without SSDs though.
My Rig:
  • CPU: 1090T@4.1ghz
  • RAM: 8GB 1333mhz
https://linustechtips.com/topic/1901-first-build-decent/#findComment-26067
I'd drop the PSU, you don't need that much wattage. Save some money and get something in the 550w range. I'd save some money on the motherboard, a cheaper motherboard will get you same benefits, there isn't much to overclocking now and is a lot less motherboard dependent than in the past. Use the saved money to get a 120gb SSD.
https://linustechtips.com/topic/1901-first-build-decent/#findComment-26070
Are there SSD's that only hold 20gb? I only really need one for my OS
https://linustechtips.com/topic/1901-first-build-decent/#findComment-26075
I'd drop the PSU' date=' you don't need that much wattage. Save some money and get something in the 550w range. I'd save some money on the motherboard, a cheaper motherboard will get you same benefits, there isn't much to overclocking now and is a lot less motherboard dependent than in the past. Use the saved money to get a 120gb SSD. [/quote']
Are there any good Mobos you could suggest? And for my GPU I need to get one which is above 600w and sorry to trouble you again Helltech haha
https://linustechtips.com/topic/1901-first-build-decent/#findComment-26085
There is 32 GB. But I would recomend getting at least 64 or 128 gb ssd. I prefer installing on ssd OS and all sowtware. Because annoying programs like photoshop or office starts instantly from ssd compared to traditional hdd.
https://linustechtips.com/topic/1901-first-build-decent/#findComment-26108
I'd drop the PSU' date=' you don't need that much wattage. Save some money and get something in the 550w range. I'd save some money on the motherboard, a cheaper motherboard will get you same benefits, there isn't much to overclocking now and is a lot less motherboard dependent than in the past. Use the saved money to get a 120gb SSD. [/quote'] Are there any good Mobos you could suggest? And for my GPU I need to get one which is above 600w and sorry to trouble you again Helltech haha
No bother, why do you think you need 600w? That isn't true at all. An overclocked system at full load with a 7970 only uses about 390w. Anyway I would suggest anything MSI, Asus, Gigabyte, AsRock that is Z77. I really doesn't matter.
https://linustechtips.com/topic/1901-first-build-decent/#findComment-26594
