What power supply?
Go to solution Solved by BradBoiii,
I'd pick the Corsair one. Higher efficiency and Corsair are a very reliable company and well know for durable products.
Although the Corsair one has 2 less amps on the 12v rail than the other one which is surprising, barely a difference though.
ive heard from an other post on this forum, that this power supply is better than this power supply, with prices aside, which power supply is the best from your experience?
Long live Stalin, he loves you; sing these words, or you know what he’ll do!
https://linustechtips.com/topic/189754-what-power-supply/
I would prefer the XFX one, though you shouldn't have troubles with either. Both are very good.
The Corsair one is more efficient, though.
You should probably go with the CSM if money isn't an issue.
Seasonic has a more reliable history, but reviews seem to indicate the CSM is better.
Error: 410
https://linustechtips.com/topic/189754-what-power-supply/#findComment-2555852
XFX end of it :P
You could get the rm650 which is fully modular and semi-passive (fan doesnt spin at low loads) for 200 things (whatever they use in sweden) more.
The RM650 is a great power supply. The fan has never turned on, the whole time i've had it! However, the flat black cables can be hard to cable manage.
https://linustechtips.com/topic/189754-what-power-supply/#findComment-2560386
