I recently bought windwos 8.1 and put it on my computer that I built back in January. I first had the computer running as a hackintosh but then I decided that for school I should put windows on it. This is where my problem begins. I was able to install pretty easilty but once I got into Windows it didn't work right and it would blue screen alot eventually it got to the point where it doesn't boot but it also won't allow my to boot of my cd of parted magic or ubuntu either. So Please help me. My hardware is
Asus p8z68 deluxe
intel core i5 3570K
16gb crucal balistix ram running at 1600 Mhz
128gb sandisk ssd
2 toshiba 1tb hard drives running in raid 0
2 xfx readeon hd 6670 2gb ddr3 viedo cards not in crossfire
1 24 inch 1080p monitor
1 23.6 inch apple cinema display at 1920x1200
The two monitors are running off of different video cards
post-84848-0-07372400-1406826853_thumb.j
That is what happens when the computer boots
Hi there. Move along, n0thing to see here.
https://linustechtips.com/topic/189736-please-help/
all that screen shows is a line.
You said you had it as a hackintosh? Did you have to manually change a bios on something? Reset everything, unplug the drives and see if it will boot to either a "No selected boot media" (or whatever) Or the blinking question mark folder of apple.
If it boots into the first option, format your drives from another computer and try again. If it boots to the folder, you are going to need to revert the BIOS of your motherboard and likely your graphics card to default.
Hackintoshing is annoying.
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/189736-please-help/#findComment-2556548
I'm not quite sure what your picture is supposed to show; is it just a black screen? Also what were your blue screen error codes?
post-89214-0-41837400-1406835707_thumb.j
CPU: AMD FX-8120 | CPU Cooler: Thermaltake Contac 30 | Motherboard: GIGABYTE GA-990FXA-UD3 | Memory: Kingston 16GB (4 x 4GB) DDR3-1333 | Storage: WD 1TB | GPU: Gigabyte Radeon HD 7870 | Case: Thermaltake Chaser MK-I | PSU: Thermaltake Black Widow 850W
https://linustechtips.com/topic/189736-please-help/#findComment-2556568
Well that screen doesn't exactly tell us much. If you can't boot off your usb I'm guessing it's either a BIOS issue or possible failing RAM. You may want to reset your BIOS and run a RAM diagnostic like Memtest86.
that image looks like what happens when you try to install windows through bootcamp and it screws up.
https://linustechtips.com/topic/189736-please-help/#findComment-2556639
