AIO Cooler Help
Solved by Jodomcfrodo,
Are you asking if there is a better performing 360mm solution? If you want the best cooling go custom loop. If you change your fans, you will see a decrease in noise and a 3c-10c difference in temperature depending on how terrible the fans that come with your AIO are.
3
thedood2k ·
Posted in Power Supplies2 -
DARTHDIVIDER0213 ·
Posted in Troubleshooting8 -
1
Xx-albinos-xX ·
Posted in Troubleshooting10 -
2
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
