I just built a new computer and my frame rates are awful for what they should be and I don't know the problem.
MSI Twin FROZR  Gtx 760 4 gb oc edition factory overclocked
MSI a88x g45 fm2 motherboard
Amd Athlon x4 760k
8 gb of ram some old ram
Corsair rm750
1tb hdd
nzxt source 210
I would love some help and feedback on this issue because im getting some terrible framerates in games most games at very low are running at 30 fps max
My bad and most games such as skyrim, league of legends, borderlands 2, planetside 2, dishonered, cs:go, and other games
latest drivers
https://linustechtips.com/topic/187370-frame-rates-really-slow/
MSI Twin FROZR 4 gb oc edition
Amd Athlon x4 760k
Corsair rm750
1tb hdd
nzxt source 210
You forgot to lable what GPU that MSI card is.
https://linustechtips.com/topic/187370-frame-rates-really-slow/#findComment-2521132
You didn't say what your GPU is, you just say its an 4GB OC edition.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/187370-frame-rates-really-slow/#findComment-2521136
Check whether you accidentally set your refresh rate to 30Hz as opposed to 60Hz.
If that is the case then reinstall drivers, check whether the card is properly plugged in and check the temperatures when gaming. If the temperatures are too high it will throttle so yeah that will give you horrible framerates.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/187370-frame-rates-really-slow/#findComment-2521522
Have you turned Vsync on in those games?
The refresh rate is 144Hz
https://linustechtips.com/topic/187370-frame-rates-really-slow/#findComment-2521553
Go into a game and play it for a while while monitoring your GPU activity/load with something like MSI afterburner and give us the results.
https://linustechtips.com/topic/187370-frame-rates-really-slow/#findComment-2521591
my cpu temps never go past 70 C and i was using fraps to check my fps and i check with afterburner my gpu usage never went above 50% and im confused on why because ive watched a ton of benchmarks and people are playing with my set up at max with 50-60 fps in most games
https://linustechtips.com/topic/187370-frame-rates-really-slow/#findComment-2525715
Which gpu usage not exceeding 50% you have a bottleneck. It's most likely CPU but since you said "8 gb old ram" it wouldn't hurt to replace that with solid 1600MHz memory.
Replacing the CPU with a good i5 or FX-8320/8350 (recommend i5 strongly) should alleviate the bottleneck. Not sure but an FX-6300 might suffice as well.
https://linustechtips.com/topic/187370-frame-rates-really-slow/#findComment-2527983
