Help me with psu
Go to solution Solved by Askew,
Aren't you suppose to get something more than required wattage.
A 500W unit will be ok for quality and price for 1x 270x but if you will crossfire more will be needed.
Hello guys. I want to buy a new power supply and I am stuck with 3 options
Corsair vs650
Corsair vs550
Gigabyte superb e620
Which one should I buy.
And if there are any other you can recommend under 90 bucks please do so.
Please refer to this site Use.dtcae.com
I can only buy from here or else I have to pay double the amount for shipping and stuff. From here I have to pay 30 bucks to get it to my country.
Considering I have r9270x
I53470
And I would upgrade it to i7 4970k
And some mobo with it. And please do consider a little oc.
And if possible suggest me one I can crossfire with.(optional)
Thanks
https://linustechtips.com/topic/187072-help-me-with-psu/
^ As Askew said, an R9 270X doesn't use that much. 500W is enough for a 270X and 4790k.
Thanks guys. I guess I should go with cx500
https://linustechtips.com/topic/187072-help-me-with-psu/#findComment-2518956
The VS650 costs 300.00AED. For crossfire 270X's I would recommend the CX750 or CX750M, for 430 or 440 AED respectively.
Word of advice. Stay the hell away from Gigabyte power supplies. They're known for motherboards and graphics cards, and a couple failed attempts at watercooling and low-end cases. They aren't known for their power supplies.
https://linustechtips.com/topic/187072-help-me-with-psu/#findComment-2519133
