Hello,
I have this problem , i was playing csgo and my pc just went to sleep.. It hapens sometimes usualy after that i need to restart it then i dont hear the beep( system sucesful boot notification) then some restarts switch offs and im fixed , but now i tried my fix rutine and it didint work, no beep, black no video imput screen on my monitor.. When i turn it on my HDD light glows long without shutering and then switches off completely.. I tried reindtaling the gpu and reseating most of the plugs... When i removed my gpu it made beep eror codes that gpu isint instales and etc so i instaled it back and again no boot...
Plz help me fix this...
Note i hear a metal chirping squeky sound when i boot from the HDD but it did it always
https://linustechtips.com/topic/187005-pc-booting-problem/
Sounds like something has died.
I'd probably remove your HDD and see if it can post without it.
Also sounds like maybe PSU based on the previous issues, they can click sometimes when triggering the over current protection.
https://linustechtips.com/topic/187005-pc-booting-problem/#findComment-2516198
Well my OS is inside the hdd and no post
https://linustechtips.com/topic/187005-pc-booting-problem/#findComment-2516208
You can POST without an OS. Just try removing the HDD :)
https://linustechtips.com/topic/187005-pc-booting-problem/#findComment-2516223
Ok so did some reaserch and tried things to fix it and to force the beeps
I hafe an Gigabyte S-series Ultra Durable 2 GA-P35-DS3R
Ok so i tried:
Flashing CMOS- didint work
Tried removing the CMOS battery- didint work
Removed the HDD- didint post. No beep sound or any signal of hdd failure
Removed the RAM - beeped alot.
Removed the GPU second power conector- constant beep
Removed the GPu - gpu failure beep sheme
Ok so i think these are the problems:
1.The motherboard is trash worthy
2.GPU is cousing an error
3.The Ram is cousing an error
4.Ram and GPu are both cousing and error
5. The motherboard is broken and the beeping from the ram and gpu is just an informator that theyr not pluged in ( theirn not broken just not conected)
6.Both the GPU and Mobo is ded
7.Both the RAM and Mobo is ded
https://linustechtips.com/topic/187005-pc-booting-problem/#findComment-2516605
Ok so i tried:
Sounds like time for a new PC :(
You might spend more replacing things than is worth it.
RIP PC, may GabeN gide you.
https://linustechtips.com/topic/187005-pc-booting-problem/#findComment-2516872
Funny fact that it died while i was playing csgo :DD gaben curse
Died playing a glorious PC game, it's an omen!
https://linustechtips.com/topic/187005-pc-booting-problem/#findComment-2516942
i would connect the hdd to another pc and try if its ok. when not perhaps you install a fresh os on anther hdd and give it a try
Desktop Build Log http://linustechtips.com/main/topic/486571-custom-wooden-case-with-lighting/#entry6529892
thinkpad l450, i5-5200u, 8gb ram, 1080p ips, 250gb samsung ssd, fingerprint reader, 72wh battery <3, mx master, motorola lapdock as secound screen
Please quote if you want me to respond and marking as solved is always appreciated.
https://linustechtips.com/topic/187005-pc-booting-problem/#findComment-2523135
Cosnidering it
  • fails POST without boot drive (which is not required to pass POST)
  • you hear a clicking
Your issues is either a dead PSU (clicking being the over current protection tripping), or, you have CPU/GPU fan causing one or the other to overheat damn near immediately, and failing POST.
"Any sufficiently advanced technology is indistinguishable from magic" - Arthur C. Clarke
Just because it may seem like magic, I'm not a wizard, just a nerd. I am fallible.
Use the quote button or @<username> to reply to people | Mark solved troubleshooting topics as such, selecting the correct answer, and follow them to get replies!
Community Standards | Guides & Tutorials Troubleshooting Section
https://linustechtips.com/topic/187005-pc-booting-problem/#findComment-2527869
