Something like the NH-D15 from Noctua is really your best bet in my opinion.  If you want better cooling than that, the only thing that really performs a good bit better than the NH-D14 is something like the Cooler Master Eisberg  240L
https://linustechtips.com/topic/186994-cooler-for-oc/#findComment-2516132
The Cpu is the i7 4790k.
Dark rock pro 3, NH-U14s/D14/D15
phanteks ph-tc14pe
Will all reach 4.5ghz If you have a avarage chip.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/186994-cooler-for-oc/#findComment-2517285
