Windows 8.1 pro problem
We need more information than that to do any form of diagnoses.
Try giving us your hardware, like CPU, and RAM, and a list of any 3rd party software you have installed that could cause a longer boot, like Stardock Fences 2.0
"Any sufficiently advanced technology is indistinguishable from magic" - Arthur C. Clarke
Just because it may seem like magic, I'm not a wizard, just a nerd. I am fallible.
Use the quote button or @<username> to reply to people | Mark solved troubleshooting topics as such, selecting the correct answer, and follow them to get replies!
Community Standards | Guides & Tutorials Troubleshooting Section
https://linustechtips.com/topic/186942-windows-81-pro-problem/#findComment-2520679
I was using my computer and windows 8.1 pro just started lagging like crazy where i could't do anything. I tried starting it up again several times but it would take forever and when it did load i would have the extreme lag again.
can i have your pc specifications ?
and what windows 8.1 you running ? 64 bit or 32 bit
32 Bit required 1GB RAM
64 Bit Required 2GB RAM
And How many cores and Ghz your CPU Have ?
Windows 8.1 32 Bit Required 1 Ghz
For More Information of system requirements Go To
http://windows.microsoft.com/en-us/windows-8/system-requirements
make sure your system pass the the requirements
Current Build + Setup
AMD Ryzen 7 5700X | GIGABYTE B550 Aorus Pro v2 | CORSAIR Dominator Platinum 16gb 3600Mhz | GIGABYTE RTX 3070 AORUS MASTER OC 8 GB | NZXT H510 Elite | 2TB Seagate Barracuda 7200RPM | ADATA XPG GAMMIX S7 512GB M.2-2280 NVME | Corsair RM850 80+ Gold Modular PSU | NZXT Kraken X63 | Harman Kardon Soundstick 4 | Koorui 27E1Q
https://linustechtips.com/topic/186942-windows-81-pro-problem/#findComment-2521000
His system has to meet the minimum requirements, else Windows would not install. Been that way since XP that I know of (was too young to ever use anything before it)
https://linustechtips.com/topic/186942-windows-81-pro-problem/#findComment-2521027
you know what i mean right ?
we need he's system requirements for solve his problem
it may cause he only have 2gb of ram and installing 64 bit
it will be laggy because my friend pc lagging when installing 64 bit but only have 2GB Of RAM
https://linustechtips.com/topic/186942-windows-81-pro-problem/#findComment-2521071
My guess is, since OP said "just started lagging" this is a new issue, and having 2GB of RAM would've affected OP earlier. Yes though, we do need the specs to try and narrow down a diagnosis.
https://linustechtips.com/topic/186942-windows-81-pro-problem/#findComment-2521106
just started lagging ??? that maybe cause of program
https://linustechtips.com/topic/186942-windows-81-pro-problem/#findComment-2521296
