does the cloning software clone the os ? i'm talking about the samsung cloning software software  if it doesnt clone the os is there something that does ?
 can clone data from hdd to ssds in raid 0, or clone it to the pci ssd and can u use it as a boot drive ? (if only some pci ssds can be booted from pls let me know witch ones)
 what would you recommend for upgrading shall i go raid 0 with 2 ssds or get like a plextor or the OCZ pci ssds ?
i plan on upgrading later this year so if theres anything i should wait for let me know
https://linustechtips.com/topic/186627-no-longer-using-topic/
Wait for native pci-e drives (marvell, sandforce). Those will git 2GB/s easily and will be a single controller solutions (not unlike almost everything else today that uses raid0).
+°´°+,¸¸,+°´°~ Glorious PC master gaming race :wub: ~°´°+,¸¸,+°´°+
BigBox: Asus P8Z77-V, 3570k, 8GB Ram, Intel 180GB & Sammy 750GB, HD4000, W7
PiBox: Rasberry Pi, BCM @ 1225Mhz ^_^ , 256MB Ram, 16GB Storage, pIO, Raspbian
https://linustechtips.com/topic/186627-no-longer-using-topic/#findComment-2513024
