Hey everone, I am currently a college student and plan on moving around quite often, mainly during the summer for jobs and back to school. As such, I want a PC that I can take with me, while still being plenty powerful. I started having doubts about my current build plan today, and thought maybe a smaller case/mobo combo might be in order.
My current build is here: http://pcpartpicker.com/p/2NTnyc
What are some good cases that can fit in a suitcase/box/travel well? I would preferably like to not ship the PC every time I move.
https://linustechtips.com/topic/185919-portable-pc-case/
Lian Li PC-TU200. Won't be a good choice for your graphics card, but is best for portability and sexiness. If you want something small, you need a reference cooler on your gpu. Some other options that might have enough airflow for a dual fan cooler are Fractal's Node 304 or Silverstone's RZV01.
I should be studying.
https://linustechtips.com/topic/185919-portable-pc-case/#findComment-2500222
With your ATX, not many small cases are out for ATX... http://pcpartpicker.com/p/gWHZ99
CPU: Intel i5 4570 | Cooler: Cooler Master TPC 812 | Motherboard: ASUS H87M-PRO | RAM: G.Skill 16GB (4x4GB) @ 1600MHZ | Storage: OCZ ARC 100 480GB, WD Caviar Black 2TB, Caviar Blue 1TB | GPU: Gigabyte GTX 970 | ODD: ASUS BC-12D2HT BR Reader | PSU: Cooler Master V650 | Display: LG IPS234 | Keyboard: Logitech G710+ | Mouse: Logitech G602 | Audio: Logitech Z506 & Audio Technica M50X | My machine: https://nz.pcpartpicker.com/b/JoJ
https://linustechtips.com/topic/185919-portable-pc-case/#findComment-2500227
how large is this suit case???....
He did mention in the PCPartPicker list that he has purchased only the CPU, HDD, SSD and GPU. Everything else is open for change.
https://linustechtips.com/topic/185919-portable-pc-case/#findComment-2500257
@pdawg Corsair are coming out with a new super-portable Mini-ITX gaming case, maybe worth a look?
http://www.tomshardware.com/news/corsair-graphite-series-380t,27060.html
Seems to be based off the 250D but with better cooling and handles and stuff. Not that most hardware has any cooling issues in a 250D, as people have run 290Xs and stuff, so your hardware will be fine.
https://linustechtips.com/topic/185919-portable-pc-case/#findComment-2500485
Corsair 380T, it should be available in a month. You'll need to change your motherboard.
Anyway you've got a really great PC there, what do you want to do on the portable one? Maybe you would just leave it as it is and just build a portable PC for office programs, internet etc?
Then I would suggest a case that doesn't fit in a suitcase... but is a suitcase: http://www.lian-li.com/en/dt_portfolio/pc-tu100/
https://linustechtips.com/topic/185919-portable-pc-case/#findComment-2501713
Might be worth waiting for the 380T if you can.
Otherwise I'd go with the Elite 130. You'll need a mini ITX board. I don't think your PSU will fit in this case so I'd go with the Silverstone ST65F-G. If your overclocking your CPU you'll need an after market cooler, can't be any more than 65mm in height.
https://linustechtips.com/topic/185919-portable-pc-case/#findComment-2504425
