Alright so basically i bought a new AMD 8320 to replace my AMD Athlon 2 x3 and the motherboard was a MSI 970A-G46 which can handle AM3+ CPU's. So i put in the new cpu and no post, so i figured maybe i flashed the bios wrong. So i put back in my Athlon because i knew that it worked. But it didn't post. I searched for hours looking for a reason and nothing. So i bought a new motherboard the ASUS M5 A99FX PRO 2.0 thinking well it should work after i update the bios which i triple checked to make sure it was updated and it was so i put in the new CPU and well with this motherboard there are LEDs that come on to show when parts are on and the CPU LED came on and the RAM LED came on but the Graphics LED didn't and im using a GTX 560ti. So i switched the graphics to an old GT 520 just to make sure, and still the Graphics LED doesn't come on still. I probably should've said this before but with my old Athlon everything worked just fine no problems. So i looked around the net to see how often CPU's come DOA and everyone says little. Im currently RMA-ing the FX chip but i was wondering if it was something else and maybe one of you guys have an answer. Ill post the rest of my specs below
Graphics card: GTX 560ti
Power Supply: Thermal Take tr2 600W
Memory: G Skill 4 gb
Hard Drive(s): 500gb wd blue and 1tb wd blue
CPU Cooler: Cooler Master Hyper 212+
UPDATE: Got the new CPU today and everything works, so i was apart of the super slim chance of getting a broken CPU :)
EDIT: Fixed the CPU name.
https://linustechtips.com/topic/1857-sadly-a-no-post-issue/
Interesting.
What is the beep code?
It might reveal more.
EDIT: I double checked for you and you are correct saying both motherboards support the chip.
You got your 8 and 3 mixed up in the cpu name btw!
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/1857-sadly-a-no-post-issue/#findComment-25285
Interesting.
Sadly i dont have a motherboard speaker... And thank you didnt realize i made that mistake Would it be the power supply i did a power calculator and it said i was fine but ive made mistakes before.
https://linustechtips.com/topic/1857-sadly-a-no-post-issue/#findComment-25316
600W is definitely enough to POST.
Does the computer post without a GPU? Just out of interest.
https://linustechtips.com/topic/1857-sadly-a-no-post-issue/#findComment-25348
Yeah it does look like CPU. :/
https://linustechtips.com/topic/1857-sadly-a-no-post-issue/#findComment-25421
