I'm choosing a mobo for gaming that is both red and black, That can use the following components.
My maximum price here is $350 but i'm looking to save as much as possible without sacrificing performance too much.
CPU: Intel Core i7-4770K
CASE: Aerocool Strike-X Air
G-Card: Nvidia GTX 780ti
https://linustechtips.com/topic/184806-need-help-choosing-a-mobo/
The MSI Z97-G45 gaming would be perfect, it will allow you to overclock the CPU as much as you want, is packed full of nice features and support dual GPU's (SLI/crossfire),
it's all you need really i wouldn't go any higher unless you plan on running 3 or 4 graphics card, solid board for the price:
http://pcpartpicker.com/part/msi-motherboard-z97g45gaming
You could also look at the newer MSI Z97 Gaming 5 motherboard wich is basicaly the same it has all the same features:
http://pcpartpicker.com/part/msi-motherboard-z97gaming5
I find the dragon head shaped heatsinks on the G45 sexier but this is just personal opinion!
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
