I want to build a PC to use for gaming with a budget of $1100. I would prefer to buy everything from Amazon.
This is my parts list so far:
CPU: Intel Core i5-4570 3.2GHz Quad-Core Processor  ($189.99 @ Amazon)
Motherboard: Asus H97M-E Micro ATX LGA1150 Motherboard  ($98.24 @ Amazon)
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1600 Memory  ($76.99 @ Amazon)
Storage: A-Data Premier Pro SP600 128GB 2.5" Solid State Drive  ($64.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon)
Video Card: Gigabyte Radeon R9 280X 3GB WINDFORCE Video Card  ($299.99 @ Amazon)
Case: Corsair 350D Window MicroATX Mid Tower Case  ($99.99 @ Amazon)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($64.99 @ Amazon)
Monitor: Dell S2340M 60Hz 23.0" Monitor  ($144.99 @ Amazon)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  ($37.72 @ Amazon)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($29.99 @ Amazon)
Other: Windows 8.1 Pro ($69.99)
Total: $1227.86
I would like to get the price down to about $1100 without sacrificing much performance.
https://linustechtips.com/topic/184559-first-pc-build/
Total: $1227.86
Change the CPU to a i5 4690, other than that it's ok :3
My rig: Intel Core i7 4790k | MSI Z97 PC Mate | GSKILL Ripjaws X 16GB 1866MHz | ADATA Premier SP550 480GB SSD | Seagate Barracuda 3TB | Seagate Barracuda 2TB  | MSI Gaming X GTX 1070 | Thermaltake Versa N21 | Corsair CX550M Semi Modular PSU | AOC G2460PF 144Hz | Logitech G502 | GSKILL Ripjaws KM780  | GAMDIAS HEPHAESTUS V2  PCPartPicker | Old Build Log | New Build Log
https://linustechtips.com/topic/184559-first-pc-build/#findComment-2480374
Total: $1227.86
Go with a cheaper H87 motherboard rather than H97, http://pcpartpicker.com/part/asrock-motherboard-h87mpro4 for example.
Other than that, you can choose cheaper versions of everything you posted, but then you risk dealing with a less-than-highest-rated company. (like, you could get a mushkin SSd, go with some weird color ram, HIS GPU, etc).
Do you need wireless? Gaming on wireless is less than great in general, so, you could get a 100ft ethernet cord for $15 instead of the 37 for a wireless card.
I would reccomend a 550W GOLD rated, like http://pcpartpicker.com/part/corsair-power-supply-cs550m. Supposedly the CSM has better innards than the CX too.
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
https://linustechtips.com/topic/184559-first-pc-build/#findComment-2480441
You could try finding a 7970 that wasn't used for mining on the used market. That'd shave ~$160 off your cost.
Honestly you're already pretty close to the bottom unless you want to switch over to AMD, or ditch the SSD.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/184559-first-pc-build/#findComment-2480446
Total: $1227.86
"Okay" Build But Would Recommend switching out your SSD and HDD for a Single SSHD
like This: http://pcpartpicker.com/part/seagate-internal-hard-drive-st1000dx001 (you just saved a lot of Money and start saving up for the SSD if you want to)
a Hybrid Gives you the Speed of a SSD with the Capacity of and HDD It Prioritizes your most used apps to run like "SDD Speeds" During loading
I would Recommend switching out your RAM with these Pair of Bad Boys: http://pcpartpicker.com/part/gskill-memory-f38500cl7d8gbrl
They Have The CAS of 7!!
I Love Dogs and Video Editing
https://linustechtips.com/topic/184559-first-pc-build/#findComment-2480447
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($149.99 @ SuperBiiz)
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard  ($119.98 @ SuperBiiz)
Memory: Patriot Viper 3 8GB (2 x 4GB) DDR3-1600 Memory  ($74.94 @ Amazon)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card  ($339.99 @ Newegg)
Monitor: Acer G226HQLBbd 60Hz 21.5" Monitor  ($99.99 @ Newegg)
Other: windows 8.1 @G2a ($20.00)
Total: $1115.83
https://linustechtips.com/topic/184559-first-pc-build/#findComment-2480491
No loss of performance. All sourced through Amazon. Not quite $1,100.
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard  ($95.99 @ Amazon)
Memory: Kingston Blu 8GB (2 x 4GB) DDR3-1600 Memory  ($75.99 @ Amazon)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  ($54.99 @ Amazon)
Case: Cooler Master Elite 130 Mini ITX Tower Case  ($49.99 @ Amazon)
Power Supply: Rosewill Hive 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($64.99 @ Amazon)
Total: $1126.89
https://linustechtips.com/topic/184559-first-pc-build/#findComment-2480908
