Heyy guys!
So recently i decided to take apart my whole pc and re-do it cause my cable management sucked the problem i encountere is that when i was done and started re connecting everything back together i forgot the atx 12v 2x4 connector but i had my graphic card hooked up and my pc started for a second and stopped then i hooked the atx 12v 2x4 connector but nothing not even 1 second start when i took it off and i took the graphics card off too and reconnected the atx 12v 2x4 connector but nothing not even the 1 second start it does with the graphics card hooked in ... What could it be and what can i do?
PC SPECS:
CPU: i5-7600K | MOTHERBOARD: ASUS STRIX Z270E | GPU:ASUS Geforce GTX1070 STRIX | RAM: Corsair Vengeance LPX 16GB DDR4 | CASE: Corsair Graphite Series 760T | PSU: EVGA SuperNOVA GQ | DISPLAY : HP Pavilion 22xi x3 | HDD: Western Digital 1TB Caviar Blue x2 SSD: SAMSUNG 850 EVO COOLING:Noctua NH-D14
Peripherals :
HEADSET: Logitech G430 | MOUSE : Logitech G502 | MOUSEPAD : Razer Goliathus | KEYBOARD: Corsair K65|
https://linustechtips.com/topic/184495-mobo-problem/
Does your MB light up? maybe a faulty PSU or MB.
What are your Specs?
Heyy guys!
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
https://linustechtips.com/topic/184495-mobo-problem/#findComment-2479247
When i say it starts for a second i mean every fan turns on
My specs are gigabyte z77 mobo with a gx lite cooler master 750 w psu i5-4570 cpu and gigabyte gtx-560
PC SPECS:
Peripherals :
https://linustechtips.com/topic/184495-mobo-problem/#findComment-2479337
Anyone?
PC SPECS:
Peripherals :
https://linustechtips.com/topic/184495-mobo-problem/#findComment-2479793
Maybe try cleaning the CMOS and updating the BIOS.
Check everything is connected correctly.
Is your PSU modular etc? check they are correctly connected to the right bits.
Anyone?
https://linustechtips.com/topic/184495-mobo-problem/#findComment-2479906
PSU isn't modular and i'll check the other possibilities thanks i hope anything of this works
PC SPECS:
Peripherals :
https://linustechtips.com/topic/184495-mobo-problem/#findComment-2479937
Do you not get any POST? do you have a internal speaker that can do the POST beeps?
Check the HDD cables too.
Edit: just looked and your MB has dual BIOS, try the other BIOS.
Edited by William12h
https://linustechtips.com/topic/184495-mobo-problem/#findComment-2480100
I have a thingy attached on the motherboard for the beep but nothing that thing goes off after 2-3 seconds pc starts for only 1 also :P how can i access the bios since i can start it for 1 second and without the atx 12v 2x4 connected?
PC SPECS:
Peripherals :
https://linustechtips.com/topic/184495-mobo-problem/#findComment-2480150
Silly question: did you connect the 4+4 12v cable to power the cpu?
I'm a newbie so i'll just tell you what i did i just took a 6 pin cable from my psu and putted it into my motherboard 4+4 12v input
PC SPECS:
Peripherals :
https://linustechtips.com/topic/184495-mobo-problem/#findComment-2480475
So, you connected a 6pin cable to a 8 pin connector?
as far as i know my psu doesn't have an 8 pin connector soo yeah? :ppp
PC SPECS:
Peripherals :
https://linustechtips.com/topic/184495-mobo-problem/#findComment-2480506
lol, i don't think so
If you connected a 6pin cable to a 8pin connector you may have shorted the cpu.
Find the 4+4 pin cable and connect it to the 8pin connector located in the top of the mobo.
So i will take 2 4 pins and put them in the 4+4 am i right?
PC SPECS:
Peripherals :
https://linustechtips.com/topic/184495-mobo-problem/#findComment-2480574
Yes!
Oh gosh it works now .. I thought of that but i remembered that the previous time i hooked only one cable! Oh well thank you so much both!!!!
PC SPECS:
Peripherals :
https://linustechtips.com/topic/184495-mobo-problem/#findComment-2480630
I'm glad to hear it works now :)
Usually, the 6(+2)pin cable is for PCI such gfx cards, and the 4+4 pin cable is for the CPU.
Good to know from now on so i will stop being a complete idiot with that connector cause it always..ALWAYS gets me ! :po
PC SPECS:
Peripherals :
https://linustechtips.com/topic/184495-mobo-problem/#findComment-2480693
