I had a couple question, I just bought a new GPU (EVGA GTX 660 SC) and I was wondering if it was good with my CPU and the rest of my components, if there's no bottleneck.
Motherboard: Asus P7P55D
CPU: Intel i5 750 (I overcloked it to 3.6 GHz) My CPU temp never go over 45-50 degrees when I play Battlefield 3 for exemple.
GPU: EVGA GTX 660 SC
RAM: Kingston HyperX Genesis 8 Go (2x 4Go) DDR3 1600 MHz
Hard Drive: Western Digital 64MB Cache SATA 6.0Gb/s
CPU Fan: Cooler Master Hyper 212 with only one fan on it, planning on adding a second one on it.
Case: Antec Three Hundred Case (I added 2 fans in front, i have one on the top, one in the back and one on the side panel)
I was planning on getting a SSD soon to upgrade from my HDD, I would like to have recommandation on which one to get. I was maybe thinking a Crucial M4 256Gb. I don't need more than 256Gb and was looking for something under 300$, I'm open for suggestions. If there's no bottleneck do you think it would be good to overclock my GPU or it's already superclocked and there's no point of doing something with it. When I play Battlefield 3 on high/ultra grahpics my GPU temp don't go over 70 degrees.
Thanks Guys!
https://linustechtips.com/topic/18439-need-help/
I was ok with my CPU Fan, I wasn't sure if i should OC my GPU. I wasn't sure which SSD to get under 300$. Have you seen good reviews on the Samsung 840 250GB. I heard that the Crucial M4 was good but i want other suggestions hehe. i will probably get one in a month. I will go and check out the Samsung.
https://linustechtips.com/topic/18439-need-help/#findComment-215008
