Working on a new build and money is a little tight so i want to save on anything i can without sacrificing much performance so i have picked 2 power supplies one is a high quality one but theres a much cheaper one that i could get but im not sure if i should skimp out on a power supply links to the power supplies and the build it will be going in, thankyou for the help everyone
Power supplies:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438011&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1990102&csid=_61
The build:
http://pcpartpicker.com/p/PhtRYJ
https://linustechtips.com/topic/184245-power-supply-help-please/
I would get the AX1200i. If you don't have enough money to buy a quality PSU, then you don't have enough for your build.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/184245-power-supply-help-please/#findComment-2475738
I would say never skimp on your PSU it will be the thing that will keep your components running but can be devastating to your components when it fails. I wouldn't go the coolmax route I do not trust them enough. But if you find the EVGA to expensive look into other options there are a lot of PSU's on the market from brands like coolermaster, BE QUIET! and many more. You should look into those for sure!
I5-8600K - GTX 1080 - 16GB RAM - 1.5TB SSD
I want everything pink
https://linustechtips.com/topic/184245-power-supply-help-please/#findComment-2475749
OK, just for the record, 3 way CF/SLI is worthless you'd be better of buying a More powerful single card, or just Two Cards and call it a day, and i suggest a Seasonic X Series 1250W 80+Gold, relatively Cheap, very Good build quality, and as every body else said, never skimp and buy a crappy PSU, if it fails, you're screwed
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/184245-power-supply-help-please/#findComment-2475755
Never skimp on your psu.
https://linustechtips.com/topic/184245-power-supply-help-please/#findComment-2475756
If you skimp  on a good quality power supply you'll definitely run into a lot of trouble. I'd say any 850w-1000w with a decent silver minimum 80+ efficiency will be borderline. @Awesome274
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/184245-power-supply-help-please/#findComment-2475775
Anything from Corsair!
i5 4670k, GTX 970, 12GB 1600, 120GB SSD, 240GB SDD, 1TB HDD, CM Storm Quickfire TK, G502, VG248QE, ATH M40x, Fractal R4
i5 4278U, Intel Iris Graphics, 8GB 1600, 128GB SSD, 2560x1600 IPS display, Mid-2014 Model
All the parts are here, just need to get customized cords to connect the motherboard to the front panel.
https://linustechtips.com/topic/184245-power-supply-help-please/#findComment-2476007
