What's your load?
It's about 30 celsius in my room(somewhere around 28-29) and my idle temps(chrome open with 5 tabs) are 36 celsius (4670k, hyper evo).
if you disable C states that happens.
If it's 30C in your room, then yes there's your answer. That's 86F, which almost 90F which is extremely hot for a room with a computer. For example my room in the summer is always 20-21C.
You might want to invest in an air conditioner.
100% on 3 cores, fluctuating on the last one.
But I am not doing anything really.
100% load?
What are you doing?
What's your load?
Huh... odd...
I have Chrome open with 19 tabs. League of Legends launcher, spotify, a Skype call, sticky notes, and a file.,
Got couple of PC's with idle not passing 35C... Why? Because A/C.
|EVGA 850 P2| |1440p PG279Q| |X570 Aorus Extreme| |Ryzen 9 3950x WC| |FE 2080Ti WC|TridentZ Neo 64GB| |Samsung 970 EVO M.2 1TB x3
 |Logitech G900|K70 Cherry MX Speed|  |Logitech Z906 |  |HD650|  |CaseLabs SMA8 (one of the last ones made)
Huh... odd...
What's your CPU load with almost nothing open?(other than idle and essential processes)
I'm not getting 71 Celsius even while rendering.
100% load during that doesn't seem realistic to me.
What's "GfjdkpfhrU.exe?"
Directory : %APPDATA%\WiseManager\CGMInerDLLs
It's a hidden mining application.
WiseManager.exe(whatever that is) contains it.Remove both that and the mining software from the msconfig start up.
Then delete it from its' directory(uninstall if you can)
Don't know :x
Maybe spyware. Try downloading Spybot 2 (free) and Malwarebytes Anti-Malware (free 30 day trial). Run both of them separately and see if they find any spyware running. Do full scans on both. Also when you run Spybot 2. Close down your internet browser.
Oh shit, so somebody is bitcoinmining here?
I updated my initial post.See if that works.
Do you have any program called WiseManager installed?
Yeah the process. Not sure about the program.
Check.
Try uninstalling.
Also,remove it from the start up list(in ms config)
Yeah, removed the processes and temps went down instantly.
You just closed it down. Since the program is spyware it will load up probably the next time you boot up your computer. So run those Anti-Spyware programs I recommended to completely get rid of it. If that doesn't work follow these directions:
WiseManager.exe(whatever that is) contains it.Remove it from the msconfig start up.
Try uninstalling it.
If all else fails,try deleting.
