and os
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/18406-help-d/#findComment-214539
try reinstalling you gpu and all the connecters. thats a video error
https://linustechtips.com/topic/18406-help-d/#findComment-214553
  • 2 weeks later...
there's a hotfix provided by microsoft provided in the article... i just don't know if that will fix it. but since this is from microsoft, i'm pretty sure that it will fix it.
I was just about to say the same thing
My specs are near exactly the same, and i've gone through that just recently as well (the 6770 is a rebrand of the 5770 with some tweaking).
https://linustechtips.com/topic/18406-help-d/#findComment-256579
