Ive been trying to put texture  packs onto skyrim ever  since i had gotton my new graphics cards, but all th differant  texture packs that i loaded only had textures for select areas meaning that the road may be 4k but the grass beside it would be vanila. so i heard then that there was a texture pack combiner that everyone raves about and i thought i would give it a go. to start, one of the essential texture  packs isnt even available anymore (Skyrim Realistic Overhaul) as the mod creater had been baned from the nexus, it said that the  mod will work without it but it wont be the same, s i thought nothing of it and continued to download all  of the other nesisery  mods and  about 80% of the  optional ones making sure that there was a texture pack that covered everything. in the end, the results were horendus, textures were all  differant resolutions, 20 meter draw distances, textures being missing, flora being verythin even though i installed the summer verion and  textures being low resolution .i.e the flora mod. but one of the things that anoyed me the most was the fact that sometimes in the distance,  depending on what way you looked, the distant terain would just disapear. i see the likes of brodual's skyrim and it looks great, i  understand that he has a few other mods on but for the most part he uses this method.
if anyone could help me i would be  in debt to you. ive literaly tried this on 5 differant occations and to the same result. if anyone has any sujestions as to alternative  mods, by all means let me know.
any help or input is welcomed.
post-107821-0-67914000-1405818107_thumb.
post-107821-0-27232700-1405818175_thumb.
post-107821-0-55099500-1405818245_thumb.
post-107821-0-81662000-1405818344_thumb.
post-107821-0-81357200-1405818392_thumb.
post-107821-0-79851500-1405818426_thumb.
post-107821-0-39514800-1405818461_thumb.
post-107821-0-55353000-1405818485_thumb.
post-107821-0-96243400-1405818533_thumb.
post-107821-0-63043600-1405818596_thumb.
post-107821-0-11116100-1405818642_thumb.
https://linustechtips.com/topic/183763-skyrim-texture-pack-not-working/
SRO may be down on the Nexus but a YouTuber, hodilton, has a backup of it: https://mega.co.nz/#!5cxRyRZQ!Xm3wHmCYWm9Bt23HETGrKZA7n0w0HYQitfHeg29W44Y Maybe getting it will fix the issues you're having
i5-4670k @4.2GHz Sapphire Tri-X R9 290 @1135MHz 1600MHz G.Skill RipjawsX 8GB Samsung 840 EVO 120GB Samsung 850 EVO 250GB
Corsair K70 Logitech G502 Proteus Core Logitech G230 Blue Snowball SteelSeries QcK+
YouTube // Steam // Twitter // Facebook // Google+
