I'm looking to build my first custom PC for gaming and video editing.
My budget is around $800 - $1000 Im in the US.
I made my own build here which is a bit expensive but looking for more option or things i can spend more money on now and don;t have to later or spend less money now and get something better later on.
So i would appreciate if you guys can help me choose some parts to my first build also it would be better if the parts are from Amazon. Thanks
Here current parts I've chosen so far but a bit expensive.
http://gyazo.com/4b9ae1a100a8bd9b7b00d7b8566aa996
http://gyazo.com/269a923c3e6820f7742c7eb22b9e7e42
What are some parts I can remove or change for something else.
https://linustechtips.com/topic/18353-first-build/
Is Newegg okay for you?
https://linustechtips.com/topic/18353-first-build/#findComment-213855
Take out that power supply first of all get a 750w or 850w upgrade the 660 to a 660ti get a razer deathadder instead that ram is overkill 16gbs of vengance 1600mhz or 8gbs will be more that a enough and wait for the new intel cpus get a ssd as well
Is the RAM too much? Really? I will be doing a lot of rendering videos and I thought i need alot. And they told me that the intel i5 3570k is good because you can easily overclock it.
Not really looking more for Amazon since I have the credits on my Amazon account.
https://linustechtips.com/topic/18353-first-build/#findComment-213863
PCPartPicker part list: http://pcpartpicker.com/p/YLQv
Price breakdown by merchant: http://pcpartpicker.com/p/YLQv/by_merchant/
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor  ($209.99 @ Amazon)
CPU Cooler: Corsair H100i 77.0 CFM  Liquid CPU Cooler  ($109.99 @ Amazon)
Motherboard: Asus P8Z77-V LK ATX  LGA1155 Motherboard  ($129.99 @ Amazon)
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory  ($99.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($69.99 @ Amazon)
Video Card: Asus GeForce GTX 660 Ti 2GB Video Card  ($289.99 @ Amazon)
Case: NZXT Phantom 410 (Black) ATX Mid Tower Case  ($84.50 @ Amazon)
Power Supply: Corsair Enthusiast 650W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply  ($89.99 @ Amazon)
Total: $1084.43
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-05-21 02:54 EDT-0400)
Edit: no price on the case, my bad.
Edit2: replaced the list
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/18353-first-build/#findComment-213895
Here's what I came up with:
http://gyazo.com/82369e1fec4426229dbb0179bdc7e09a
http://gyazo.com/118984c6097b329b59082d457cbba654
This should be a more balanced sub-$1000 system.
I think 12gb ram would be more fitting but what-the-hey--I have 16gb myself.
https://linustechtips.com/topic/18353-first-build/#findComment-213912
