Overclock going bad/Motherboard Help
Solved by Guest,
Nothing is going bad, if you get that error in the event viewer it means that your overclock is unstable. Now the error may only occur in games and not when you test it with prime.
You just need to tweak around with voltage and LLC-settings to find out when your CPU starts being completely stable @4.2GHz.
Also, disable Intel SpeedStep in your bios. It should be stable at around 1.2-1.3V though.
