onboard sound
Go to solution Solved by Sors,
soo they dont?
No, they don't.
Usb headsets use a sound card build in.  That bypasses the soundcard in the PC completely.
Onboard outputs to any rear audio ports and the front audio ports if they are connected. That's it.
GG best post stolen from under your nose. Try again next time, newb.
https://linustechtips.com/topic/183150-onboard-sound/#findComment-2462641
