Any way to replace a switch?
Go to solution Solved by peaking duck,
you could open it up and check the solder points for that switch.
or better yet, order a replacement switch from wasdkeyboards.com before hand just in case u need to replace it
So I've been with the keyboard (K60) for 2 years now, and the "e" key has been starting to fail, sometimes it registers twice, sometimes it's just doesn't register at all, so my guess is that the switch is starting to die (?) so I was wondering if instead of getting a new Keyboard, I could just get another switch and change it for a new one
MSI Z87-GD65 - GTX 760 DirectCU II - i5 4670k @4.0GHz - 16GB Corsair Vengeance @1866 MHz
https://linustechtips.com/topic/182881-any-way-to-replace-a-switch/
I had the same issue with my K60, I've even ordered the replacement switches already but haven't gotten around to fixing it.
Here's where I bought them, they're cheaper per switch than wasdkeyboards: http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=845
[spoiler=pc specs:]cpu: i5-4670k | mobo: z87-pro | cpu cooler: h100i | ram: 8gb vengeance pro | gpu: gtx770 ftw 4gb | case: nzxt switch 810 matte black | storage: 240gb ssd; 1tb hdd | psu: 750w corsair rm |
keyboards: max nighthawk x8 mx brown + blue led; corsair k60 mx red; ducky shine 3 tkl mx blue + orange led | mouse: deathadder black edition | audio: FiiO E10; sennheiser hd558; grado sr80i; sony mdr-nc200d; blue snowball |
